max crashes when wiring custom parameters
  • max crashes when wiring custom parameters
    Hi all
    I'm wiring some custom attributes of an object, but max crashes most of the time as soon as I "connect".
    The times it actually works, the object itself then makes max unstable. When I copy the object with the custom attributes, its fine mostly, but it crashes if I instance it?!?
    Any thoughts?
    I've tried with Max 2012 and also 2014, same result
    Kind Regards,
    Morne
    Can you post a scene that shows the problem?
    Dan Brew
      Sent you a PM
      Kind Regards,
      Morne
