Hopefully this is simple and possible.
How may I have the max standard multi/sub-object material, use vray materials instead of standard?
For example, if I were to add another material to the multi/sub, it uses a standard material by default causing a few extra steps, each time, to replace it with vraymaterial.
TIA
edit:
max2014
vray2.X
TIA
edit:
max2014
vray2.X
