Lattice Mod, Rotate Segments?
  • Lattice Mod, Rotate Segments?
    Hi all
    Is there way, perhaps maxscript, or another modifier that I can put on top of the stack, that will let me rotate the segments of the Lattice Modifier? (by default it comes in at 45 degrees)
    Kind Regards,
    Morne
    I dont believe so. can you not inset the polygons, delete those faces and use shell?
      We're automating the creation of various similar components of different sizes from just using referenced splines. Will have to find another way I geuss
      Kind Regards,
      Morne
        if it's from a spline why cant you use sweep?
        if it's from an object can you create a macro?
        run this, change inset amount to whatever you need. add shell modifier afterwards.
        macros.run "Modifier Stack" "Convert_to_Poly"subobjectLevel = 4
        actionMan.executeAction 0 "40021"
        $.EditablePoly.SetSelection #Face #{1..999999}
        $.insetType = 1
        $.insetAmount = 3.19618
        $.EditablePoly.buttonOp #Inset
        actionMan.executeAction 0 "40020" -- Edit: Delete Objects
        $.EditablePoly.delete #Face
          Didn't think of macro, thanks will give it a shot
          Kind Regards,
          Morne
