Sweep with a 3d closed spline ?
  • Sweep with a 3d closed spline ?
    I know this problem and it's really painful. Anyway, I always do that kind of shape in another way but I'm just wanting to know if someone have any tricks to deal with that problem's sweep.
    All advices are welcome !! Thanks
    (Sorry for my bad english)
    Break the vertices and weld them again sometimes works.
    Other times reversing just 1 segment of the spline works
    Kind Regards,
    Morne
      when you display the vertex numbers are they in order?
      val valgardson
      http://www.photorealistic-rendering.com/
        Whenever that happens i go to edit poly, select all the vertical faces and bridge the open borders
          Doesn't clicking 'Banking' usually fix this? I think i remember sometimes it doesn't...
            No way :/
            Either break and weld or reversing doesn't work
            Yes
            It's always what I do
            Not really, banking don't give the good result in this kind of stuff.. I want something straight, with banking, you will have a distortion on the 2 corners
            Anyway, thanks guys !
