I often get contour lines from clients. Often they are good, but sometimes there are some engineer-slop splines that have each vert at a different height.
(Each vert is at it's own Zed elevation.)
Here is an image from front/side view...![Click image for larger version
Name: Q_flatten spline.jpg
Is there a quick way to "flatten" these crap lines?
I know in AutoCAD there was a command for doing this in about 1 second. Would be surprised if I have to trace over the contour in order
to get the lines flat (at zero elevation.)
I've a few scripts that help with the number of vertices, but nothing to deal with vertex heights within a spline.
TIA
TIA
