Populate 2015 save path vs 2014
  • Populate 2015 save path vs 2014
    Hi all
    OK so my workflow for 2014 worked great for me. I move the populate files from my temp folder to the server and just repath to the server. All is great in lala land
    But now with 2015, all is messed up. When I use the default populate settings (not saved) and I try to use my 2014 workflow, it works great until I close my file and open it. Then it auto repaths to the temp folder.
    If I enable the new save path feature in 2015, then it creates a NEW folder in the same location as my max file and it names the folder the same as my max file. This is a problem if I alternate between 3 file names for backup purposes. I end up with 3 different populate folders containing the same files. If I repath these files, next time I open the max file it auto repaths to the folder same as my max file name.
    Is there an INI file or something I can adjust to fix this issue?
    I can set my temp folder to the server, but that is NOT ideal as it creates a bunch of other issues.
    Any suggestions?
    Kind Regards,
    Morne
