Maxscript help changing name of objects
  • Maxscript help changing name of objects
    Hi all
    I have an array of objects
    inside
    Code:
        countBB = 0
        for obj in bbObjsArr do
            obj.name = "sdgfdgf" + countBB
    countBB = countBB + 1
    But its not working
    even if I say
    thisnumber = countBB as String
    and then change the naming to
    obj.name = "sdgfdgf" + thisnumber
    it still doesnt work
    Kind Regards,
    Morne
    Using 'as string' should work.
    This works for me:
    Code:
    	local objsAR = getCurrentSelection()
    	for i = 1 to objsAR.count do objsAR[i].name = "NewName" + i as string
    Dan Brew
      You could also use UniqueName() then you don't have to add the numbering yourself.
      www.suurland.com
      www.cg-source.com
      www.hdri-locations.com
        Could you elaborate a little on that one?
        How would I use it in my example code?
        Kind Regards,
        Morne
          With your code it would be something like:
          bbObjsArr = getCurrentSelection()
          obj.name = uniquename "Name"
          www.suurland.com
          www.cg-source.com
            This works for me:
            Code:
            Both work great, but for the current situation, uniquename worked better
            Thanks guys
            Kind Regards,
            Morne
