MAXScript add or replace extension during filesave
  • MAXScript add or replace extension during filesave
    Hi all
    Using maxscript, I'm having the user type in the name of the vrimg file to save and then I'm setting that in the Raw Image save path etc.
    I'm not sure how to set the extension if the user does not type it. Also if the user types an extension, how can I ignore it and use a specific extension?
    Currently I have:
    Code:
        on test pressed do
                f = getSaveFileName caption: "save A Test File:" \
                filename: "C:/_VRay RAW Renders/" \
                types:"V-Ray image files (*.vrimg)"
                if f!=undefined then
                        renderers.current.output_rawFileName = f
    Kind Regards,
    Morne
    this seems to work:
    Code:
    g = (getFilenamePath f) +  (getFilenameFile f) + (getFilenameType "*.vrimg")
    Kind Regards,
    Morne
      You forgot the | for GetSaveFileName
      So it would be this:
      Code:
      f = getSaveFileName caption:"Save a test file" filename:"C:/_VRay RAW Renders/" types:"V-Ray image files (*.vrimg)|*.vrimg"
      Colin Senner
        Code:
        Aha, that's it. Thanks Colin that did the trick
        Kind Regards,
        Morne
