MAXScript output size glitches
  • MAXScript output size glitches
    Hi all
    I'm setting the max outputsize for the common render dialog, but I'm having a hard time for the settings to take effect
    I've tried various things
    just before setting the outputsize:
    Code:
    renderSceneDialog.close()
    after setting outputsize
    Code:
    renderSceneDialog.update()
    When I do this with buttons, it mostly works
    When I do it with spinners, it only works sometimes?!?
    Code:
        on spnWidth changed val do
            renderWidth = spnWidth.value
        on spnWidth buttondown  do
        on spnWidth buttonup  do
    I do the same for the height, but no matter if the dialog is open, closed or updated I get glitches
    Kind Regards,
    Morne
    Hmm - spinner updates might be a nasty one - they're constantly updating so your dialog is caught in a hell of open and close as you drag over the spinner - might be better to have an overall apply button for the ui so it's a single command rather than a constant bombardment of them?
      Try using the 'entered' event to trigger the update:
      Code:
      	rollout rSize "Render Size" width:140 height:65
      		on rSize open do
      			rSize.rWidth_sp.value = renderWidth
      			rSize.rHeight_sp.value = renderHeight
      		spinner rWidth_sp " Width:" pos:[35,10]  width:80 range:[1,10000,0] type:#integer
      		spinner rHeight_sp " Height:" pos:[35,35]  width:80 range:[1,10000,0] type:#integer
      		on rWidth_sp entered do
      			renderWidth = rWidth_sp.value
      		on rHeight_sp entered do
      			renderHeight = rHeight_sp.value
      	createDialog rSize
      John is right though, it can be difficult to get the right value if the user 'spins' to enter a value. A plain textBox would be an alternative if you can't get it working reliably.
      Dan Brew
        Hmmm thanks John and Dan
        That gave me an Idea. Instead of updating the output "realtime", I'm just going to do it at the end when the user click a button. Will also be a lot less code
        Kind Regards,
        Morne
          Yeah, it's not as if renderwidth is something you'd be scrubbing up and down to try and find the right spot either - most people have an exact idea of what they want and punch it in right away.
