PC Maintenance
  • PC Maintenance
    Do you guys do anything, other than the typical defrag, to maintain your PC's. I have tried everything, but to tell you the truth, I think most do more damage than good. My last utility was the WinZip System Utilities Suite, which seems to do good things, but it started to look spammy by all these "offers".
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    nothing at all. AVG used to be good but even that now has constant pop ups and multiple processes kicking in at startup. ESET endpoint antivirus and spotify are the only things in my system tray.
      It seems like all these companies are grabbing at ways to monetize.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I rarely do anything to my workstation. If you work clean, no bogus software, just your tools you should be just fine. With this said though, I do run a smart ssd app to monitor ssd life / health.
        Generally any issues I have are hardware related (due to age) of my system.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          What do you use to monitor you SSD?
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Mine is looking pretty strong.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              SSD life pro.
              Dmitry Vinnik
              ShowReel:
                I was told you have to let it run in the background for some weeks before you can trust its opinion.
                Dmitry Vinnik
                ShowReel:
                  I'll have to purchase; I used the trial
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I wouldn't recommend defraging an ssd by the way. There won't be any noticable change in speed with an ssd even though it's heavily used. But defragmentation of an ssd decreases its lifespan faster.
                    A.
                    www.digitaltwins.be
                      good to know. I just defraged, but won't do it again.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Yeah, no need to defrag an SSD. One can get decent performance defragging a traditional platter hdd, reducing the amount of movement the heads need to make while accessing the various bits of information.
                        Troy Buckley | Technical Art Director
                        Midwest Studios
                          A few months ago I decided to purchase and install the whole suite of AVG software on my laptop at home - an ageing Dell XPS machine. It ran through everything telling me what programs should be stopped to improve performance, which things could be improved etc. Also, when I plugged it into the power, it ran various things to make the machine run better, restoring a battery mode when I was disconnected from the mains.
                          It all looked quite clever, and I was quite happy.
                          however, a few months on and the system just seemed so slow. Just unplugging the mains cord resulted in delays where the AVG tried to improve performance for running on a battery. Pop ups started telling me to do this that and the other. Really annoying.
                          It got to a point where I uninstalled everything related to AVG.
                          Since then, everything is really good again!
                          Kind Regards,
                          Richard Birket
                          http://www.blinkimage.com
                            That seems to be their MO - At first they seem to do good, but in the long run they do more harm than good.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              I backed a kickstarter called Jumpshot at the time that was later purchased by avast, it is now called grimefighter. It was pretty neat and worked well on most of the PCs that I tried it on. It would basically do it's sweep in one session without any residual effects. The one time that it did mess up, I was able to go right back into it and undo the changes it made.
                              Made quite a difference on one of my older laptops.
                              Ben Steinert
                              pb2ae.com
