I wonder what would be a viable low-budge workflow (no Faro or LIDAR involved) for highest possible photogrammetry-based set reconstruction for entire entire exterior/interior enviroment.
Say you take HDRs at multiple survey positions along with many many (tens or hundreds) still photos, how would you solve camera positions for reconstructing the set in your DCC application...I have seen couple demos by Scott Metzger but that's with a FARO and he solved camera position of still photos via measurements. I am looking for a semi-automatic to automatic solution for solving camera position for both stills and HDR survey points.
1. Photoscan: pro version is expensive and not sure if either version works with spherical images.
2. PFTrack: significant amount of still image to manually solve can be painfully time-consuming and cluttering the UI.
3. NukeX: the still image solver appears to me more for reconstructing partial environment.
Look forward to hearing your thoughts.
cheers.
cheers.
