Remove Interpolated reflection/refraction
  • Remove Interpolated reflection/refraction
    I have tried to remove all interpolated reflection/reflections from a scene with a lot of materials.
    However when I am rendering it still does the interpolated passes, Is there a script or something that can check or find materials with this option checked?
    This drives me crazy.
    -Tom
    -Tom
    VMC can edit multiple values at once for a whole scene including reflect interpolation and refract interpolation, you will have to run the script a few times with the different default values you have in mind for each option but it will get the job done in a few seconds. http://www.scriptspot.com/3ds-max/sc...terial-control
    A.
    www.digitaltwins.be
      Thanks, I just found the last material with interpolation - finally!
      It would be nice for the next time tough..
      -Tom
        -Tom
        VMC is a must for batch material changes.
        A.
        www.digitaltwins.be
          Next time use this:
          (---subdivs
          val = off
          vmtl = getClassInstances VRayMtl
          for i in vmtl do i.reflection_useInterpolation = val
          for i in vmtl do i.refraction_useInterpolation = val
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
