VMC (VRay Material Control) ... v2.11?
  • VMC (VRay Material Control) ... v2.11?
    I can't get the new version 2.126 work, it keep throwing me errors "syntax error: at keyword parameter, expected name"
    Do any one got the v2.11 version?, i reformated my pc so i lost that version (im on vray 3.15.01)
    Arch Pedro A. Solano
    "Save the irradiance map, save the render"
    Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
    Follow us on facebook
    Visit us on PSolano
    So I can fix the issue, can you let me know what you are trying to do when you get the exception?
    Many thanks,
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
      Hi olly,
      I just installed, created a button and press it to run the script
      Visit us on PSolano
        Hi oligophant,
        I never managed to reproduce the error you were getting, but I have published an update that may fix your issue.
        Fixes:
        Fixed “Unable to convert: “” to type: BooleanClass” bug
        Fixed “Turn off store with ir map” for vraylights (Power Tools)
        Fixed “Turn off reflect on back side” button (Power Tools)
        Fixed “All proxys to point” (Power Tools)
        Added “Remove selection’s materials” (Power Tools)
        You can download the update here: http://www.oliverradford.com/3ds-max...erial-control/
        Cheers,
        Olly
