Material variation/iteration script?
  • Material variation/iteration script?
    Does anyone remember a material variation script that was posted here a while back? I believe you would select the variables you wanted to see and it would render out the variations. Thanks
    Yep, I did one. It's called Tweaker
    http://www.colinsenner.com/scripts
    Colin Senner
      Thank you!!!
        Colin, I just tried it out in Max 2015 (64b) SP3 and I get an error: --No ""getPropNames"" function for undefined and line 101 is highlighted in the MaxScript window on line 101: local cProps = getPropNames tw.obj.controller (I'm trying to run variations on a dent map used as a displacement.) The properties of the map come up in the far right column, but none and accessable. Max just beeps when I try to double click a property. Any ideas?
          One sec Jeff. Let me look at it. I wrote it back in Max 2009, so let me fix any issues with 2015 and get back with you in a few minutes.
          Colin Senner
            I've updated it to version Tweaker_11 on my site that works great with Max 2015. It's now able to be installed as a button and is located under category: ColinScripts. Select "Pick Map" browse down to "Scene Materials" and locate your Dent map (I tested this, works great).
            Please report back your eminent success .
            Colin Senner
              Fantastic! Works like a charm!!!
              Than you so much for updating this. When the time come, I'm voting for you as Chaosgroup Forum Member of the Year!
                Haha, no problem. It needed to be updated anyway. Enjoy.
                Colin Senner
