Weird AutoCAD linking on import
Yes, I have seen this. I think I imported the CAD, export it as an OBJ, and import it again... Something like that. It happens with Revit models, too.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Originally posted by glorybound View PostYes, I have seen this. I think I imported the CAD, export it as an OBJ, and import it again... Something like that. It happens with Revit models, too."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
I had this issue just last week. http://forums.cgsociety.org/showthread.php?t=1230561
It's due to instanced transform controllers on imported objects that are blocks within AutoCAD; to fix it (thanks to SnipeyX for the script and PixelMonkey for telling me to use the full maxscript Editor)
1. select the offending objects
2. open the MaxScript editor and copy-paste and run the following:
for o in selection do o.transform.controller = PRS()
for o in selection do o.parent = undefined
)Last edited by Richard7666; 13-02-2015, 10:59 PM.
Originally posted by Richard7666 View PostI had this issue just last week. http://forums.cgsociety.org/showthread.php?t=1230561
Again, won't work in the listener, use the MaxScript Editor. Thanks to SnipeyX at CGsociety for the script
Thanks Richard! Works like a charm!"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
