Large Store front Rendering
  • Large Store front Rendering
    Hi!
    I have a request to do a large rendering for a storefront (14' X 10') since the resolution on this would be insane can anyone recommend how to approach this? like DPI and GI solution I assume I'm going to need to rendering it in parts but not sure.
    I would greatly appreciate any advice!
    -Eric
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
    I would call your local reprographer; you might be surprised on the low resolution it might require. Also, you can get away with upsizing it.
    http://www.on1.com/store/perfect-res...-edition-full/
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      do it 10k wide and scale up to 200dpi using one of those smart image scaling bits of software. this also works apparently - http://www.alienskin.com/blowup/
        I did renderings for large format prints a couple of times and the guidelines were always the same : give us a 300 dpi image that is 1/10th the printed size. So that's only 30dpi.
        mekene
          blow up never worked for my. I have it, but don't use it.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            10k will give you 60ppi, which looks sharp at a viewing distance of 4 feet away. you could probably go lower and do a 5 or 6k image with one of those image scalers, 10 is absolute maximum for high quality
              Thanks all!
              at 10k my render times seem reasonable.
              Thomas A. Edison
                The 'Preserve Details (enlargement)' algorithm built into Photoshop's image size tool is pretty decent, even provides a noise reduction effect in the process.
                Ben Steinert
                pb2ae.com
