VRayLight Maxscript access to "Units": Default
  • VRayLight Maxscript access to "Units": Default
    For VRayLights is there MAXScript access for the units of the vray light?
    The reason is we're having major problems in scenes because Radiant Power/Luminous Power distribute light problematically when the lights themselves are scaled down.
    In Vray 2.5 this isn't a problem, but you can see in 3.0 either "power" settings different.
    Colin Senner
    If you are asking about changing units type command, it's "normalizeColor". I tried to reproduce your problem, but I couldn't -
    Peter Matanov
    Chaos
      As illustrated, please scale a light and set the units to "Radiant Power", not radiance.
      "Radiance" and "Luminance" do not have this problem, only the "Power" versions of these.
      Colin Senner
        I can get you a scene if you like
        Colin Senner
          It would be good to check out a scene, though I'm not quite sure it is a bug - still would be good to check.
            Sure thing Vlado. Give me a few and I'll get it to you. Thanks for looking into it. I'm not sure it's a bug either, just wanted to get clarification on the issue.
            Colin Senner
              Here's the scene. Note: this behavior is not synonymous with vray 2.4.
              https://teague.boxcn.net/s/gnalpzehe...dx6i7mvjkzqx24
              Colin Senner
                Were you able to replicate this behavior on your end? I can dig deeper if you weren't.
                Thanks.
                Colin Senner
                  Yes the issue is reproducible with the provided scene, last time you forgot to mention that the lights in your scene are not uniform scaled .. and have tweaked directional parameters
                  Peter Matanov
                  Chaos
                    My apologies. I'm just reporting the issue for a coworker who asked I post it. Sorry about that . Thanks for following up.
                    Colin Senner
