Mighty Instruments
  • Mighty Instruments
    So, is Mighty Tile gone? Is anybody using Mighty Instruments?
    http://www.mighty-instruments.de
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I have it, but decided not to renew this year. They have switched to subscription only, and IMHO, too expensive.
    For the number of my jobs per year that absolutely require it, the price is just too high.
    If the price were a one time purchase, I would not hesitate to buy it again.
    Other than that issue, it's a great product and I wish I could keep it active.
    Hope that helps
      Something like $250 a year, correct? I am simply looking for a way to create bricks. I have a building with the same brick, only used in different ways across the building. Specifically, standard course and herringbone.
      Hope that helps
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        You will be able to all that and more, if you want to cough-up the dough
        It does the mortar, too...total control, semi steep learning curve, IMO. But support is quite good and it really is powerful, I don't want to knock the tool, just the cost.
          Walls & Tiles should have worked, but my scene became very unstable while using it, so I pulled its plug. I emailed them, but I haven't heard back.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I have both, and FWIW, I had an easier time learning MTPro. But VP is usually great regarding support.
            I don't recall any stability issues with W&T. There's a new version I'm beta testing that's Omnitiles. It looks like it will be a lot more powerful, like MTP.
            MTP also has a Photoshop version of the plugin, just for making maps to use inside of max.
              Maybe, I'll wait for Onitiles
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
