Sige RALsolidColor texture - gamma question
  • Sige RALsolidColor texture - gamma question
    I need to assign RAL colours and siger has a free script for this. In their texture you can also select the gamma.
    My question however, does their gamma asume your system is setup for 2.2? Because if you add whatever gamma in their system, but you switch of max material affected by gamma and color pickers etc, then the siger gamma is questionable
    I'm after specific colours, and even if I google images of it those colours, I get way different results.
    My photoshop doesnt seem to have RAL colours either so I cant even verify there...
    Kind Regards,
    Morne
    nevermind
    a "RAL color chart" google did the trick
    so then if max is setup to 2.2, then you also need to add 2.2 in the RALcolorSolid it seems, then its pretty close to what it should be
    Kind Regards,
    Morne
      if your workflow gamma 2.2 - enter gamma correction value 2.2 (darkening color). Color data a bit obsolete. In near future plans new plugin for RAL colors with updated color data (old data from Autocad RAL palette).
      Regimantas Valiukas
      SIGER STUDIO
      www.sigerstudio.eu
        Originally posted by Siger View Post
        Thanks for the feedback. Can you thumbsuck an ETA on this?
        Kind Regards,
        Morne
          Whenever I have a color to match, I go to
          http://www.easyrgb.com/index.php?X=SEEK
          And do a <Photoshop swatch> with the RGB, load it as a bitmap in 3dsMax, and therefor more flexible for gamma setup.
          Alain Blanchette
          www.pixistudio.com
            For now it is difficult to say...
            Regimantas Valiukas
            SIGER STUDIO
            www.sigerstudio.eu
              Thanks... Very useful
              paolo vaja
              www.3d-arch.it
