bercontiles and multitextures
  • bercontiles and multitextures
    hi all
    I would like to randomize multitextures with bercontiles but I don't get it to work...
    I followed this instructions, (bottom) but it doesn't work. http://www.klaasnienhuis.nl/2012/01/.../#comment-8950
    either the tiles (in my case 70x35cm) are ok, or the tilemap (in my case stonetexture), but never both...
    anybody have experience with it?
    need help.
    thanks
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    I know this isn't the answer to your problem but the walls&tiles plugin from Vizpark does all that more or less automatically.
    On the other hand if you still want to go that way, you might want to post some images to make yourself a little more clear
    A.
    www.digitaltwins.be
      yes I know, and I have it. but for me the learning curve to use self made textures is too much at the moment. or do you have a good reference about it?
      Pixelschmiede GmbH
        You mean using your own created multi-textures and use them with the walls&tiles plugin? What are you struggling with?
        A.
        www.digitaltwins.be
          don't know exactly... I try 1.4 and let you know...
          there is a mistake on the reference page on vizpark... http://c2n.me/3ilZ6c2.jpg
          Pixelschmiede GmbH
            hi all
            ...the tiles (in my case 70x35cm)...
            need help.
            thanks
            best regards
            themaxxer
            Make a new bercontile and leave everything default.
            Now enter the sizes of your tile (70 X 35)
            Set Softon to None
            Disable Round Corners
            In the "None" next to the white swatch stick in a multitexture and select all your bitmaps. In multitexture make sure to tick "Bercontile" in the middle of the interface so that it will randomise over the tiles of bercontile
            Now go back to bercontile and scroll down a bit and tick "Enable Tile Mapping"
            thats it
            If you have only 1 jpg in your multitexture, you can get variation by adjusting the "random" spinners of the gamma or hue within multitexture
            Kind Regards,
            Morne
              thanks morné
              I have tested it but it doesn't work... http://c2n.me/3inXFF4.png
              the plane is about 140 x 140 and the tiles are 70 x 35 so I should see them...
              but I get one big tile... I think there is an issue with mapping scale, tiling, etc.
              I think I need a mapping for bercontile and one for the tilemap. but how?
              thanks for ideas.
              best regards
              themaxxer
              Pixelschmiede GmbH
                Since this bercontile is a procedural you don't exactly need UVW mapping. Are your units correct?
                I have attached my scene as an example. As well as a screenshot:
                A.
                www.digitaltwins.be
                  thanks morné
                  thanks for ideas.
                  best regards
                  themaxxer
                  This is 3 X jpgs in a multitexture. The small plane is 140 x 140 and the large one is 300 X 300 each with realworld scale mapping (or uvmap and realworld ticked)
                  The tiles are 70 x 35
                  Works fine here
                  Kind Regards,
                  Morne
                    really funny... doesn't work for me... http://c2n.me/3ioUdz4.jpg
                    here is the scene (2014) too... does it work for you?bercontile.zip
                    thanks
                    themaxxer
                    Pixelschmiede GmbH
                      oh I found it out... default blur 1.0 gives this http://c2n.me/3ioWU50.jpg
                      with blur 0.001 like in your scene it looks like this: http://c2n.me/3ioXlXu.jpg
                      funny! so maybe I didn't see my textures sharp...
                      best regards
                      themaxxer
                      Pixelschmiede GmbH
                        right, now it works also for me, with blur 0.001... http://c2n.me/3ioYykv.jpg
                        but morné doesn't set it to blur 0.001, so why is it working for him?
                        thanks guys!
                        best regards
                        themaxxer
                        Pixelschmiede GmbH
                          Your scene looks fine, indeed the blur needs to be put way down. Morne's blur has been put down too (=0.01)
                          A.
                          www.digitaltwins.be
                            yes I saw it afterwards... well now it works. don't know why this blur value doesn't work like normal in max.
                            Pixelschmiede GmbH
                            • #15
                              Morne especially has turned off filter
                              (Sorry for my bad english)
