Coding Advice
  • Coding Advice
    In one of my "pie in the sky" moments I sometimes think I should learn to code. There is Maxscript of course, and the related MCG in 2016 which would seem the most useful from a 3D Arch-Viz standpoint. Then more generally there is Python, and a whole host of others. I realise that learning a language is dependant on what you want to do and the platform. Is learning C relevant these days considering many language syntaxes are derived from it? Is Vray coded in C? Let's say you wanted to make your own Max plugin? ...and so on
    Sorry for the vague questions
    I had the same moment 6 years ago, and it was the most rewarding move I ever made, creatively speaking.
    Originally posted by Bruce Hart View Post
    I realise that learning a language is dependant on what you want to do.
    This is an important aspect. You can always learn a language without having an actual use for it, but it will be much much harder. Learning something which almost instantly starts to help you in your daily work gives you a lot of motivation to continue and improve.
    MCG is not exactly a programming language, so I won't comment on it. I am not convinced that using it is a stepping stone to coding, though it will probably be the most instantly gratifying.
    Basic Maxscript is very useful to know as a 3dsmax user even if you are not writing tools, and is not that hard to pick up.
    I don't know how well Python is integrated into 3dsmax, but it has the added advantage that it would also be useful in other places, not just 3dsmax. It's one of the most widely used languages today. It's also not very hard. Because it is so popular, there is also much more learning material for it.
    I would start with either MXS or Python.
    The 3dsmax SDK is based on C++, not C. C++ (and in some market segments, C) is still a relevant language today because of its portability, power and breadth. The learning curve however, especially for C++, is much steeper than MAXScript or Python. Additionally, to write 3dsmax plugins, it's not sufficient to know C++, you must also be familiar with the 3dsmax SDK.
    There is also C# or other .NET languages to consider, which IMO is easier to learn than C++, and can also be used for many things in 3dsmax and the Microsoft environment in general.
    There are many other languages worth knowing of course, but none that will help you in 3dsmax.
      That's a great answer RotemS. Thank you for your insights. I think I will just try with Maxscript for now, and in turn Python. As you say - unless you are using it regularly, things will soon be forgotten - so C (while interesting) will likely be a waste of time in my case.
        Check out my blog... It'll get you started with maxscript.
        Maxscript made easy....
        davewortley.wordpress.com
        Follow me here:
        facebook.com/MaxMadeEasy
        If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
          Dave's blog is an AWESOME resource for learning MAXScript!
          It's helped me greatly get up to speed quickly!
          Thanks to Dave for putting the effort into such a great site for helping out those who are code challenged!
          Troy Buckley | Technical Art Director
          Midwest Studios
            most coding ive done recently is for a live graphics system to run graphics for live tv
              I will indeed!
