Colormunki calibration
  • Colormunki calibration
    So I bought a colormunki, and calibrated both my monitors. Both the same monitors but they are slightly different calibrated, I did the ambient, and the glare calibration so it might have something to do with that. Also, my cursor is now extremely white in comparisson to the white of this website for instance. Is that normal?
    A.
    www.digitaltwins.be
    It will take a few hours to get use to it, but it's well worth it. I just have to add you should do the advanced calibration, not the default one. It seems more accurate that way.
    Now remember to copy the profile of your main screen that the VFB is on, then rename the extension to .icc and load that into the VFB settings. Use this from now on instead of the default sRGB. Your render will then look the same in VFB and PS if you save linear.
    Kind Regards,
    Morne
