Random delete
  • Random delete
    Is there a way to select a bunch of things and randomly delete a percentage of them? I have some ground cover, but I have way too many instances of the plants, so I want to randomly delete, let's say 20% of them.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I'll try this:
    http://emrahgunduz.com/categories/de...ith-maxscript/
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I wrote this to make random groups or percentages:
      Code:
      macroScript select_percent_001 category:"JOC Tools"
      		rollout SelectPercent "Select percentage of objects v0.01"
      			Group "Select by percent"
      				Spinner ThePercentage "Percent to select:" type:#float range:[0.0,100.0,45.0]
      				Button DoSelect "Select Percentage" align:#right width:200
      			Group "Split into groups"
      				Spinner GroupNum "How many groups?" type:#integer range:[1,5000,5]
      				Button MakeGroups "Make Groups" align:#right width:200
      			On DoSelect pressed do
      					theSel = selection as array
      					theArray = #()
      					theCount = (theSel.count/(100.0/ThePercentage.value)) as integer
      					for i = 1 to theCount do
      						RandomPick = (random 1 theSel.count)
      						append theArray theSel[RandomPick]
      						deleteItem theSel RandomPick
      					select theArray
      			On MakeGroups pressed do
      					GroupCount = (theSel.count/GroupNum.value) as integer
      					print ("Making " + groupCount as string + " groups")
      					for g = 1 to GroupNum.value do
      						TempArray = #()
      						for C = 1 to GroupCount do
      							append TempArray theSel[RandomPick]
      						selectionsets[("RandomGroup" + g as string)] = TempArray
      	CreateDialog selectPercent width:300
        Thanks, I'll try it.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          There is also a random selection tool in the Soulburn script pack. It works off weight, exact number or percentage.
          http://www.neilblevins.com/cg_tools/...urnscripts.htm
            worked perfectly, thanks.
            Code:
                                theArray = #()
                                select theArray
                                    TempArray = #()
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
