Maxscript for finding specific bitmap
  • Maxscript for finding specific bitmap
    My Maxscript skills are pretty limited, and I'm wondering if there is a way to load a particular bitmap into a slot in the compact material editor, or even the slate editor.
    The problem I'm dealing with is the dreaded Vray error:
    warning: Texture "Map#38" returned an invalid bump normal (XYZ -1.#IND. blah blah blah"
    How do I find Map#38 in a scene with hundreds of materials and possibly thousands of texture maps?
    try the zorb script.
    it will allow you to select all objects with a "normal map" or any other type of map.
      Did you get this to work? Same issue here.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        I was able to use the slate editors search function to find mine.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          After looking for over an hour I am not seeing anything wrong with Map#1
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I don't think its really the map, but the geometry it's applied to. It seems like there are wacky surface normals that are causing the bitmaps to behave badly. Usually applying a Reset Xform will fix the problem. Or creating a simple box and attaching the offending object. For me the problem shows up with downloaded objects from sites like Turbosquid or Evermotion. I'm just grasping at straws here, but I'm guessing maybe the models are created in Maya or Blender and then imported into Max. And the resulting geometry is a little messed up. That's my non-technical, grasping at straws, and could be completely wrong explanation.
            So I find the bitmap that VRay reports as invalid, then find the material it is a part of, then find the objects the material is applied to, and then fix the geometry.
