Disk not seen.
  • Disk not seen.
    Yesterday I got a fresh new hard drive and installed Windows 7 onto it, then upgraded it to Windows 10. To make sure all my data was safe from the process, I removed my work drive from the computer. For some reason, when I pop my work drive back into the computer my new Windows install cannot see it. I freaked out for a second, but then I put my old Windows disk in and that can see it just fine.
    Any ideas?
    Thanks.
    - Geoff
    Never mind. It somehow magically fixed itself. Weird.
    - Geoff
      Oof! Now I have another problem with that drive. I can't change the drive letter. I just want it to be D. Anything else I stick in there ends up as D, but I can't switch this one. I assume it's because Disk Management says it has a Page File on it (which I can't see), so I went into the Performance Settings and made sure it wasn't System Managed, but that didn't do the trick.
      Any ideas?
      Thanks.
      - Geoff
        Never mind, once again. I realized that the drive still belonged to the old Windows disk, so I popped that back in, made the drive non-system-managed, and put the new Windows disk back in, and all is good.
        - Geoff
          Talk to yourself often?
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
