I have some errors about missing maps, using the relink script, but the maps are clearly there. I also use PathFinderPro, and that too is showing them missing, but they are there. If I manually remap the maps, it works. I have to go into the material browser, select the materials and its missing slot, and manually map it back to the bitmap. What's up with that? It's a TIFF, is that matters.
Missing Maps
Missing Maps
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Bobby Parker
phone: 2188206812
- Windows 11 Pro
I pointed to the wrong one; it is there. Everything else has always work, but not this tree in question. I would hate to break what works.Bobby Parker
phone: 2188206812
- Windows 11 Pro
You absolutely double sure that it's there? because it's not anywhere in the list (which appears to be sorted by name, so I think it should be, but it's not.) Triple check the path because I have to think it would make more sense you're mixing up numbers looking at it rather than multiple scripts being wrong. Again, what's mapped is "060_tilia_03" and there is nothing that matches that in your screenshot (even ignoring what's highlighted) the ones listed are either 060_Tilia_04 or 059_Tilia_03. Otherwise, I'd wonder about 'hidden' spaces or underscores in the name somewhere (like the asset really is just mapped to the wrong name, or the file got renamed)
