Hi guys,
I need to find a way to do this kind of stuff easily and quickly (http://www.holegrafik.fr/78-277-thic...-pop-graph.jpg)
because I'm sure to have a lot of requests and tests before to find the good one : a perforated sheet metal according to a pattern (nothing fancy !)
I have a b&w image (this is my pattern), I need to have the big holes in the black part and small holes in the white part with a transistion between
All the holes must to be align.
I was thinking to a tricky pflow setup to generate a map but I'm not sure how to do...
What I need is a opacity map at the end but I also need a setup that I can use, modify easily because as I said, I'm sure my client will be.....more than undecided !!
Thanks for any advices
