Dark
  • Dark
    Something strange is going on. I render on my machine and it looks fine, however, when someone else renders it out on their machine, it's dark. I converted the scene to a Corona scene, and it rendered dark, like when it was rendered on the other person's machine. MAX gamma is 2.2 and so is V-Ray and the VFB. This is an interior scene with an HDRI in a V-Ray dome.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Check their "fileoutgamma" in the maxscript listener - it's not set by the max gamma value rather stupidly.
      sRGB button disabled in vfb?
      A.
      www.digitaltwins.be
        it's being saved from the VFB as an EXR.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          it is enabled in the VFB
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            This is a link to how to change the file out gamma in case you were wondering: http://www.cg-blog.com/index.php/201...10-max2014.htm
            Regards
            Steve
            My Portfolio
              It sounds like maybe it's not seeing the maps. You might try to update the hdri link in the map/material instead of the asset tracker.
                It was a color mapping thing.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
