Can someone share an image, before and after it was cleaned with a denoiser? I would like to see what is an okay amount of noise that can be cleaned up and with what. Everything I tried blurs the image, almost like its a watercolor. I think noise ninja was the best that I tried.
Noise
Noise
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
the only denoiser ive ever been impressed with is the Altus one ( and the renderman one of course) which was discussed to death recently. all current denoisers ive seen ( ones that use just the single raw render) do the watercolour thing. unless you use on almost the lowest setting with an image that is probably clean enough anyway.
Vlado mentioned that most people denoise in post, and if that is the case, I wonder what is being used. Also, I wonder what you can get away with.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I usually just live with it, but my first step would be either Lightroom or Photoshop, then mask in/out the areas that needed the noise removed as a layer in Photoshop.Work:
Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
V-Ray Benchmark: CPU 00:52 | GPU 00:32
Home:
AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
V-Ray Benchmark: CPU 00:47 | GPU 00:34
https://pcpartpicker.com/list/kXKcxG
Yes, I have kept up with those, however, it doesn't seem ready for prime-time. Isn't there some coding and scripting for it to work?Originally posted by FSGFX View Postthere are two huge Altus threads here... do a search...Bobby Parker
phone: 2188206812
- Windows 11 Pro
With some of these render times I hear I was just wondering if they get a noisy render out of V-Ray and clean it in post. Heck, I can get a noisy render very fast
Originally posted by particlerealities View PostI usually just live with it, but my first step would be either Lightroom or Photoshop, then mask in/out the areas that needed the noise removed as a layer in Photoshop.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Not sure what are your steps on de-noising , are you de-noising RGB or by elements ?Available for remote work.
My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
