Need help to import a revit file (RFA)
  • Need help to import a revit file (RFA)
    I'd like to import this table
    http://www.livingdivani.it/EN/Produc...lia_p2236.aspx
    ... But we don't have revit, if some kind soul could export it from revit to any importable format (in a Solid format, it would be a plus it the revit file is a solid object)
    Thanks in advance !
    Philippe Steels
    Pixelab - Blog - Flickr
    I posted something awhile back about that. A trial of Revit allowed me to export.
    Thanks in advance !
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      +1 What Bobby said. Install a trial, then instead of opening Revit, open Revit viewer. From there export to ifc
      Then get the free ifc importer for Max
      Kind Regards,
      Morne
        It's a loophole that I am sure Autodesk close.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Guys. I was able to ask the technicians and managers of the development of many parts of 3ds max.
          RFA is the internal extension for Revit Families libraries. For that reason it is impossible and illogical to direct Importancion.
          What you have to do is insert the Family (.rfa) to a blank proyecyto Revit and save the link to the format that you want.
          The best way is to export the file to CAD format, this family with their assigned materials properly.
          Then do the import or link, for material.
          Cheers
          NOTE: remember de units and ACSISolid.
            Cheers
            Yes but you missed the point where the OP said they don't have REVIT. You can only export to CAD if you have a license
            Kind Regards,
            Morne
              Thanks all for your answers, this is insightful
              A friend was able to export me the geometry. It was triangles, I don't know if it is possible to export "object"/ NURBS/ IGES geometry from REvit but in this case, as simple mesh was enough
              Philippe Steels
