Is there an equivalent MAX command, like in AutoCAD, that allows you to pick 2 points and set a distance? When I paste a site plan, onto a plane, it is a pain to scale. Now, I move the pivot to a known point on the plan, make a box to the right length and move it to the images pivot, and scale the plane until it somewhat matches. Why can't I picket two points and tell MAX the length?
Make Length
Make Length
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
I remember in AutoCAD, you would pick point one, then point two, and type the distance.Bobby Parker
phone: 2188206812
- Windows 11 Pro
There is a script here http://www.scriptspot.com/3ds-max/sc...os-script-pack
I use the 3 point rotation script 100 times a day. But never tried the scale one, although sounds like it might be what you're looking for
3pt scale and 3pt align are my two most used scripts...
Awesome! I'll check them out. Thanks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
