Jérôme does it again
  • #16
    Originally posted by grantwarwick View Post
    Vray 3.3's variance sampling surely makes any and all tweaking null, all the work I invested into sampling is useless now anyway.
    1-50, adjust clr threshold, game over.
    Actually the majority of my work over the last month or so just does not like the new simplified way. Did one yesterday at about 2K and with threshold of 0.02 I was getting 6 hour render. After doing things manually the "old" way, with 0.01 I was getting a MUCH cleaner image in HALF the time. (0.01 with the new way just sky rockets the render times and it's still noisy)
    It seems very scene specific however since the work I did in the previous month was loving the new simplified way
    Kind Regards,
    Morne
    • #17
      @Morne
      I am pretty sure vlado would be very interested in the scene that works better with the old way.
      Cheers,
      Oliver
      https://www.artstation.com/mokiki
      • #18
        Personally, if I convert a scene mid-stream, the new render times were horrendous. However, starting a scene fresh rocks with the new normal. I am not sure what would cause this, but I am glad I am working on all new projects.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090
        • ​Windows 11 Pro
        • #19
          Originally posted by ralphr View Post
          @Morne
          Yes he has mentioned this to me also and I'm hoping to arrange something afterwards.
          Strange that you are finding it like that. There shouldnt be a difference if you start fresh or convert a scene midway or even at the end. Maybe there is something wonky in the code there when "resetting" everything to default
          Kind Regards,
          Morne
          • #20
            You have to reset completely, (swap to default scanline and back)
            admin@masteringcgi.com.au
            Mastering CGI
            CGSociety Folio
            CREAM Studios
            Mastering V-Ray Thread
            • #21
              I swap using this
              Code:
              renderers.current=vray()
              Kind Regards,
              Morne
              • #22
                Originally posted by Morne View Post
                I swap using this
                Code:
                This code only assign as current renderer engine V-Ray. Simply assign via Render Setup dialog Scanline then back to V-Ray.
                P. S. The code drops parameters, but I am not sure that it is enough.
                Regimantas Valiukas
                SIGER STUDIO
                www.sigerstudio.eu
                • #23
                  Try the code yourself. It does reset the render settings to default
                  Kind Regards,
                  Morne
                  • #24
                    Yeah that was the first thing that stroke my mind when i tried new 3.3
                    Must have felt aweful but at least people understood how sampling works
                    Can you imagine if you made mastering vray now what woudl be the content?
                    Martin
                    http://www.pixelbox.cz
                    • #25
                      Tried the latest Solidrocks and the latest VRay and the render times went down 60%, eg. a 5 hr render went down to 1.5 hours at far higher settings, so not sure if its VRay or Solidrocks or both, tried it on a few more projects and all the same result, a vast reduction in rendertimes.
                      Mayeb I have been doing it worng for the last 10 years ?
                      But I like the fact I can just slide to a setting and get the results I want.
                      • #26
                        VRay it is.
                        Available for remote work.
                        My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                        • #27
                          Really, Vray now is SO SIMPLE to optimize, you just have to play around with 2-3 settings at most and you're done, even for animation. Last time i used solidrocks was 3 years ago, then it was useful, back in IR/LC days, but now?? Can't get much simpler than it is now.
                          • #28
                            That's the beauty of this industry, but fortunately there is still plenty more work to be done and advocate for moving forward in terms of our creative control, material features and effects, the GOOD stuff we should actually be worried about.
                            Just as a musician doesn't play better by understanding how the instrument was made, neither do artists do better work by understanding the math.
                            Mastering CGI
                            CGSociety Folio
                            CREAM Studios
                            • #29
                              Interesting... I have an interior that I woke up too only being 1/2 done and 12 hours to go. I raised some settings and lowered the resolution, just to make the proof deadline, and it looked awful. I decided that I would rather be late than show something bad, so I decided to try SolidRocks. With the original full resolution and 'Very Good' settings, it looks beautiful and it took about 2 hours.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                hmm i might give it a try once again (although i ve done that many times)
                                we have a scene that computes quite long so for the comparison purposes out of curiosity if ill be able to download the ugrade for free
                                Martin
