I might be hoping for too much here but never the less!
I am trying to find a way to on mass redirect xrefs being loaded in a load of max files, so an example. I have 5 images, each image has a max file with cam and lights, and they all load the same list of xrefs. I then put the render scenes into Deadline/Backburner. Later I need to add a new scene to the xref list of all the files. I have to open them all and add the new scene. If a pre-render script could have the list of xrefs in to then the extra scene could be added in the script, and all render files would get the new scene at render time.
Secondly, is there a way for the save location in the VFB to be set through a pre-render script? So somehow you set the images save name in the VFB, but the folder structure behind the save location is driven with the script? I'm thinking here if a new revision needs to be saved and not over the original renders, then you edit the pre-render script to a new folder and they all render to that folder, with same image names etc.
This could save a ton of work, just this morning spent 3 hours opening and closing files! 18 images, 36 render files!
Or does anyone have any other options to try? I thought if you could edit a .max file in a txt editor then that would be good.
Cheers,
Mark
Cheers,
Mark
