Bump pass element
  • Bump pass element
    Anything like a bump pass element? It would be awesome to have control over bump maps in post.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hmm, that's partially normals and partially the amount of contrast in your lighting channels - bump is a renderer trick to brighten and darken a surface driven by the map - it'll affect your raw light, ref and spec. You could increase or reduce the bump slightly in post by messing with the contrast levels of your raw light. Some of the comping packages let you relight renders via normals too. There's less ways to undistort reflections / refractions though.
      I'll play with it. Like reflection and specular, it would be nice to boost wood grains and other things, in post production.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Maybe a high pass instead? http://www.photoshopessentials.com/p...pen-high-pass/
          thats a nice trick.. never used high pass.
            Does anyone know how to use the BumpNormals pass in Photoshop? Is it at all possible without plugins? I know Nuke/Fusion can handle them to relight in post.
            Software:
            Windows 7 Ultimate x64 SP1
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            Intel Core i7-4930K @ 3.40 GHz
            NVIDIA GeForce GTX 780 (4096MB RAM)
            64GB RAM
            DxDiag
              https://youtu.be/N9CTOw1lxQ0?t=12m53s
                Cool! So straightforward! Imagine the things you could do with a fresnel element plus this normals pass. Make all edges on the left side get a rim light? Nice.
                Software:
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                64GB RAM
                DxDiag
