Backup solutions
  • Backup solutions
    Hi guys. I need some advice on backup solutions in terms of hard drives. I purchased BVCkup as I was told this was a pretty seamless application and did a good job backing up files. I really need to know what drives would be best to use. I can't afford 1000's on Intel 750 or enterprise drives so really looking at a cheaper solution.
    I was initially thinking of getting a 4tb Hitachi drive as their failure rate is pretty good compared to Seagate (for example) and then having two back-ups created, one on the Hitachi and one on the external WD book drive.
    What do you think ?
    Regards
    Steve
    My Portfolio
    Nothing wrong with backing up to two external drives as you suggested, just make sure one is always off-site.
    I have an external 2-bay enclosure and the drives are mirrored RAID 1, and all of my files are within a Google Drive folder on that enclosure. Then I have a dedicated external backup drive that backs up my computer's drive and the 2-bay enclosure. Then, the contents of my Google Drive folder are sync'd to Google Drive (1TB for $10/mo).
    Work:
    Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
    V-Ray Benchmark: CPU 00:52 | GPU 00:32
    Home:
    AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
    V-Ray Benchmark: CPU 00:47 | GPU 00:34
    https://pcpartpicker.com/list/kXKcxG
      I use Carbonite, which is unlimited for something like $150 a year. The business deal also backs up external devices, like my 5TB Passport drive.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Cheers guys. I think offsite backup is a good idea. I currently back up everything to two external drives once my project is finished but nothing offsite and nothing in the short term for current projects. Time to invest !
        Regards
        Steve
        My Portfolio
          If you have a data limit on your home internet connection, keep that in mind. You should be able to minimize bandwidth on the program (Google Drive allows this) so you can spread out the data upload over a month or more.
          Also, when my system is sync'ing to Google Drive with no bandwidth restrictions, it kills my home network bandwidth and my Netflix and other streaming services are always buffering. Limiting the file sync'ing bandwidth eliminates the buffering in my case.
          Work:
          Home:
            you can also backup everything and the cheapest solution is: https://www.backblaze.com/
            Luke Szeflinski
            :: www.lukx.com cgi
