Originally posted by glorybound
View Post
Multi-Threading
Originally posted by glorybound View PostThe place I purchased it from said to contact Dell support. They told me not to touch the BIOS. So, another little hurdle.Last edited by eyepiz; 24-03-2016, 03:33 PM."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
The dell support said their records shows it is a single processor. I said it better not be and I sent them the receipt. He came back, apologized, and said that it is in fact 2 processors. He had me open the case to verify an all is good. Dell said to reset the bios, so I will and I'll see what happens.
Bobby Parker www.bobby-parker.comBobby Parker
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
The BIOS shows 2 processors. However, the performance tab is showing one. Maybe, it's tomorrow problem.Bobby Parker
phone: 2188206812
- Windows 11 Pro
That's good...It might just be a bios setting that needs to be enabled or reset. when in doubt I load a Linux boot CD and troubleshoot but Dell has great tech support I'm sure there take care of it."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
In MSCONFIG I can set the processors from 0 to 36. When I set it to 2, this is what I see, when views as logical. The left one is CPU 0 and the right one is CPU 1. When I set it to show overall, it shows the one graph. Now, if I set the MSCONFIG to 36, I get the 36 graphs when set to logical. Each processor has 18 cores, so that make the 36. If I have multithreading enables, shouldn't I see 72 buckets?
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Yeah! 2 processors just renders with 2 buckets. In msconfig I have to have it on 36, I guess.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View Post. If I have multithreading enables, shouldn't I see 72 buckets?www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
I just checked for DELL drivers and it is installing a chipset driverBobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
But I am only seeing 36 buckets. CPU-Z is showing the correct information, too.Bobby Parker
phone: 2188206812
- Windows 11 Pro
If I have not seen your post with cpu-z screen I would say that you have to go to BIOS and enable HT. In many cases it is switched off by default.
Originally posted by glorybound View PostBut I am only seeing 36 buckets. CPU-Z is showing the correct information, too.
I believe it's somewhat experimental and don't think it fires up all cores when calculating the light catch. Might want to launch DR for better performance. I think that's what vlado suggested a while back
Nice rig! Looks like everything worked out."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
