I have an Autocad model of quite a complex engineering/machine component. Lots or small objects and small radius chamfer/fillets etc.
I need to get this into Max in the best possible way so all the curves are retained as closely as possible. Regardless of my attempts so far - even setting the maximum surface deviation to 0.1mm - the geometry comes in a bit rubbish.
Any suggestions? I've tried scaling up the model in AutoCAD 10x, but the problem still doesn't really go away.
