Abandon Quicktime?
  • Abandon Quicktime?
    I was just forwarded this article.
    Ugh. Every time I make an export of a movie I do it in 2 steps:
    1) Export from Adobe to MOV with lossless PNG compression
    2) Open that movie in QT and export it using H264 compression, since QT does a MUCH better job with H264 than Adobe.
    On the plus-side, I guess I'll be cranking out movies a bit quicker. On the minus-side, my movies will be 2-5 times larger. Unless maybe there's some software out there that can replace this process?
    - Geoff
    On the plus-side, I guess I'll be cranking out movies a bit quicker, on the minus-side, my movies will be 2-5 times larger. Unless maybe there's some software out there that can replace this process?
    Doesn't After Affects need (want) QuickTime to be installed?
    A.
    www.digitaltwins.be
      Yes. I am working on some After Effects work and when you install After Effects, it tells you to install Quicktime.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Premiere Pro CS5 won't import mov files w/o QT.
          And there was a Windows bulletin saying that QuickTime should be removed from Windows. Apple also said that QuickTime will no longer be supported by Apple.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Same process here, haven't found a better (or even as good) way yet
              Problem is nearly every vfx and films studio wants dnx hd quicktimes. There's a tonne of bullshit with quicktimes internal colour space too, especially with h264. When after effects writes out your comp to a movie, it does it's own sneaky colour correction on it before it hits the quicktime encoder to try and roughly match apple's look. I'd love if it died as a format!
