Hey guys,
after many years of CG, as usual Backburner is still causing a lot of problems to me...
I can't use VRay DR because I can't run and complete a proper BackBurner job on my workstation (3ds Max 2014).
This is not the first time I setup distributed rendering network, but this time I really can't find a solution.
I run both BB Manager and Server on the same machine, with Administration rights. They both connect fine, as the Backburner Queue Monitor reports. Then from 3ds Max I send a job with a very simple scene, rendering with the base scanline render.
Then the Server fails with the usual error message:
Adapter returned unexpected code: -2 for ...
Application load error: 3ds Max adapter error: Pipe ended. : 109 ...
The Max.log reports:
Can't figure and find the problem... paths are valid, file are accessible, permissions are OK...
do you have any suggestion?
Thanks!
Code:
2016/04/19 17:11:37 DBG: [11504] [11508] Starting network 2016/04/19 17:11:37 DBG: [11504] [11508] Calling NetRenderPreLoad 2016/04/19 17:11:37 DBG: [11504] [11508] in NetWorkerPreLoad. jobFile: C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.xml; jobname: C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.max 2016/04/19 17:11:37 DBG: [11504] [11508] in Init. jobFile: C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.xml; jobname: C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.max 2016/04/19 17:11:37 DBG: [11504] [11508] in Init. calling nrGetIface. jobToSend: C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.max job:C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.xml 2016/04/19 17:11:37 DBG: [11504] [11508] in Init. nrGetIface() failed 2016/04/19 17:11:37 DBG: [11504] [11508] Error initializing System Path Manager 2016/04/19 17:11:37 DBG: [11504] [11508] in NetWorkerPreLoad. Init() failed 2016/04/19 17:11:37 DBG: [11504] [11508] NetRenderPreLoad failed 2016/04/19 17:11:37 ERR: [11504] [11508] Error loading file C:\Users\Davide\AppData\Local\backburner\ServerJob\temp.max 2016/04/19 17:11:37 INF: [11504] [11508] SYSTEM: Production renderer is changed to Default Scanline Renderer. Previous messages are cleared. 2016/04/19 17:11:37 DBG: [11504] [11508] Stop network
Thanks!
