All the xrefing, although might work, seems to be a work around. There seems to be no rhyme or reason for the circle of doom. Picking a random element seems to put the software into a tailspin, for no apparent reason.
Circle of Doom
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Sometimes running the garbage collection command in the listener window helps too "gc()"
Unfortunately in my case proxies I dont think will work for me as I have far too many moving parts in my scenes for example building an entire oil drilling rig site and animating the entire operation on the surface and below as well...Cheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
I have tried the garbage collection script, but it doesn't seem to help.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Pixelcon View PostI dunno I have gigantic scenes and never have an issue. On the other hand a colleague of mine's pc just hangs constantly. There's more to it than the scene in max IMO...
phone: 2188206812
- Windows 11 Pro
I was reading posts, waiitng for MAX to wake up from canceling a render, which take forever with displacent. I responded about the runtimebroker, so I killed it to see if MAX would wake up, and it did immediately. Usually, I give up waiting and kill MAX.Last edited by glorybound; 18-05-2016, 09:28 AM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by super gnu View Posti rarely go as far as using pro-optimiser etc. only on really big scenes that need trimming for rendering.
Do you find that optimizing everything into 20-50 objects cuts down on render times?David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAM
Originally posted by glorybound View PostI got hung again, so out of a hunch, I termantaed that runtimebroker.exe and it woke MAX up.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Oops... My proof reader is off today.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by Sbrusse View PostOk bobby just do this :
Select all -> open groups -> select all ->
repeat untill you have no more closed group -> select all
Just reply with how much objs you have in you scene, just the exact number
Yes, that's what I was thinking. I'll enable that later today.
Originally posted by Vizioen View PostOr MAX Button > Properties > Summary Info. I just tested this. Max doesnt count groups as objects, but the things that are inside groups apparently too.Bobby Parker
phone: 2188206812
- Windows 11 Pro
LOL here is my current scene, Im not sure how much more I can collapse, if I hadn't attached hundreds of objects to this point then the object count would be 15,000+ Going to dig deeper in to it today and see what I can optimize further as its not to bad at home but at my office at a file size of 2.3GB now and climbing its crippling my workstation thanks to all the other crap running in the background that IT has installed to subdue their paranoia.
-daveCheers,
-dave
2.3 GB what the hell. I've dealt with some huge models but they never exceeded 500MB and that was before I started using Xrefs/objects.
