Blending between two texture maps
  • Blending between two texture maps
    How can I control the blend/softening between two UV maps on the same bit of geometry? Ideally, I want to do this procedurally using tools like bercon with fractal noise etc. Is this possible?
Name:	UV Channel Question.jpg
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    You could use a gradient ramp (ramp type box) in a composite map as a matte for your second bitmap.
    I'll do a quick example in a couple minutes.
    Gavin Jeoffreys
    Freelance 3D Generalist
      Is this what you had in mind?
      Gavin Jeoffreys
        Oooh - that looks about right. Let me look at it more closely!
        Nice one!
        Kind Regards,
        Richard Birket
