3DS MAX 2016 Layers Stink!
  • 3DS MAX 2016 Layers Stink!
    So, 3DS MAX 2017 has been released and I am still having major problems in 3DS MAX 2016. How a mature software like this is so broken, confuses me. I can't see things I try to edit and the layer explorer is broken; both keeps be from being productive. Here is what is happening in my later explorer.
    http://screencast-o-matic.com/watch/cDhtDhi1L9
    Anybody find a workaround?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The resolution might be to low to see, but my roses are not on any layer. it says layer 0, but as you see, nothing is on layer 0. Also, I have layers that are empty, yet I can't delete them.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Pardon the small icons. The software works like freeware, so you have to expect things like this (sarcasm).
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        The small icons are fine, but the video is too fuzzy to make anything out, even if I set it to fullscreen
        Kind Regards,
        Morne
          Yes, I figured that. I am using their free service, which isn't very good
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Try this
            http://screencast-o-matic.com/watch/cDhtriiifO
            Also, I captured the runtimerror gremlin.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Not any better! I paid for a pro account, thinking I could create videos that can be watched. I guess not!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                your max window is fullscreen on a 4k monitor...
                  I'll try it again, but with a smaller MAX screen.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    change your screen resolution to 1080p before recording instead
                      I'm not exactly sure what you're experiencing, but I agree the scene explorer is terrible. It seems to have been added as an afterthought using maxscript. State sets are even worse... I used that for a project recently and once I had more than 15-20 states suddenly it stopped allowing simple things like reordering states, and kept getting maxscript errors...
                        I have elements that can't be found in the explorer. The properties might say layer 0, however, they are not there. In the example, that you can't see (my apologies) I have a couple dozen rose bushes that I have to select one-by-one to edit.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          surely you do it with maxscript.
                          found this on google.
                          -- create new layer
                          layer = LayerManager.newLayer()
                          -- set layer's name
                          layer.setname "My Layer"
                          -- add nodes to layer from selection
                          for n in (selection as array) do layer.addnode n
                          you'll obviously have to select all the objects you want to move, and it's only a quickfix but hey, it works...
                            Interesting, thanks! I have since hacked my scene to make it work, however, I'll bookmark this for next time.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              I just got an error, but thanks for the try.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
