Relink Bitmap
  • Relink Bitmap
    I have a model that I am trying to relink some bitmaps, however, every time I try, MAX crashes. I tried Collins script and PathfinderPro, but with both, MAX crashes. Anybody come across this? Any solutions?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Have you tried max default bitmap finder in utilities tab?
    Luke Szeflinski
    :: www.lukx.com cgi
      Actually, I did and that's what got me through the crashing.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        idk what's up but collin scripts manages to link to some files and then not to others, i then found the maps manually and pointed the script directly to the folder where i knew the missing bitmaps were and it stil would not link them, i did it as a test, just wont work on the remaining maps, it was full proof before but not its letting me down and uninstalling and reinstalling everything is far off now i would say, any other re linking solutions out there?
        Architectural and Product Visualization at MITVIZ
        http://www.mitviz.com/
        http://mitviz.blogspot.com/
        http://www.flickr.com/photos/shawnmitford/
        i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
          not 100 percent sure about this but i had convert paths to unc checked in max, since i unchecked it, it now finds all bitmaps, maybe this was it, its the only thing i changed in max
            Mine is not checked, so I'll check it and try the latest build. I don't remember unchecking it. Is it not checked by default?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              in mine it wasnt checked, i did it in hopes of solving the paths issue with backburner but that didnt help so i left it on and since then i was having the issues
                Thats really strange, I have been using that one for a couple years and have had no problems at all with it and I always have convert to UNC turned on. When I use RB I usually turn on search sub folders and ignore case.
                Cheers,
                -dave
                ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                  Bobby, did you ever figure this out? I'm just catching back up on this forum. Been busy. If anyone can let me know how to reproduce it (ie. if UNC paths are not checked, then it won't relink, or whatever) I'll fix it up for next build.
                  Colin Senner
                    My current go to for relinking files.
                    http://www.pixamoon.com/shop/4587562...nk-.../9337230
                      Mine is working now in 2017.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        probably I've found a bug fo RB.
                        If you have bitmaps under a VrayMultiSubTex , it seems RB can't relink anything.
                        Anyone experienced this?
                        I have 3dsmax 2016 and RB 2.09
