Grabbing large res maps from google
  • Grabbing large res maps from google
    trying to find a solution to this, grabing a screenshot from google doesn't seem to give a good resolution image unless i plan to spend hours to cut and put zoomed in map parts together which would be a real pain, any known way of grabbing large maps anyone here knows about? or anyother solution to google would be good
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
    Try this little Proggie:
    https://sourceforge.net/projects/terraincognita2/
      Something called nonimapviewer works too
        thanks guys! noni map viewer i really like, it did the trick!
          Thanks, for bringing this up
            "...plan to spend hours to cut and put zoomed in map parts together which would be a real pain"
            That`s me! damn! haha
            Thanks for the tip
            OLIKA
            www.olika.de
              arh the days before reality capture....
              glad i don't need to bother with this anymore.
                I have this workflow > Menu on the left > share or embed map > custom size (choose whatever) and then I use Fireshot to capture the entire page in firefox (the only reason I have it installed).
                That nonimapview thingy doesn't seem to be working with google maps. Stays black.
                A.
                www.digitaltwins.be
                  Why don't you grab large res maps from google earth pro?
                  The pro version does allow you to save images as large as 4800 x 3645 pixels.
                  paolo vaja
                  www.3d-arch.it
                    the two first solutions are the best, i grabbed a 28k image, that's really high res
                      Ah... Ok...
                      paolo vaja
                      www.3d-arch.it
                        I dont understad how any of those two soft works
                        With nonimap, it's a *.jar or *.jnlp extention and I don't know what to do with them.
                        With Terra Incognita, I can navigate and select a region, but how do I tell him to download in HQ ? Every-time I crop and save to whatever filetype, I have a small jpg the same size as what I have on the screen.
                        Cheers
                        Stan
                        Stan
                          That's what this is for - http://www.west-racing.com/mf/?page_id=2979
                          The height map part of it is a little low res unless you're doing a background mountain range, but it can grab maps from google earth at whatever resolution google has them at. we use it on every single large scale job.
                            That looks great,
                            Thanks for the tip
                            Stan
                            • #15
                              Heum, any ideas why when I try to enter the coordinated from Sydney Australia I get only water?
                              https://www.google.be/maps/place/33%...1.206243?hl=en
                              It seems it should be covered though
                              Thanks
                              Stan
