Corsair Link for Liquid cooling and Windows 10?
  • Corsair Link for Liquid cooling and Windows 10?
    Hi all
    Did anybody manage to get their Corsair Link working under Windows 10? I'm thinking of upgrading but the pre installation check says Corsair Link is NOT compatible
    Kind Regards,
    Morne
    It does work OK. Things to note are you are probably better off reinstalling after the upgrade. Corsair have some more recent drivers and firmware too - if you haven't already updated. There is still an issue of getting accurate temperatures if your using multiple programs to poll the temperatures at the same time (CPU temp reads about 10 degrees C below what it really is), for example intel's profiling app and motherboard background apps as well as the link usb connection that comes with the Corsair i power supplies - no issue if you just use a single app. Some people with Windows 10 have also reported having to do a registry fix to stop windows putting the usb link into low power mode also. All the best Ben
      Cool thanks for the tip
      Kind Regards,
      Morne
