MAX 2017 Boolean
  • MAX 2017 Boolean
    Just doesn't work and it is very frustrating. They changed it why I don't know. Is anybody else having issues.
    http://screencast-o-matic.com/watch/cDioo7izas
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    does that other piece of geometry need a shell on it, or some bit of thickness?
    Brendan Coyle | www.brendancoyle.com
      Usual story
      Use ProBoolean instead. Sometimes the one works, sometimes the other
      Kind Regards,
      Morne
        I ended up slicing it, but why did the change the tool that worked perfectly?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          They changed it because it DIDN'T work perfectly. Boolean is one of those things that never worked in all cases since early Max already. 2017 was suppose to fix the issues, guess they just swopped it
          Kind Regards,
          Morne
            The old booleans are still there.... I'll try to remember how to bring it back from the dead.
            Maxscript made easy....
            davewortley.wordpress.com
            Follow me here:
            facebook.com/MaxMadeEasy
            If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
              It has always been buggy, but why change everything, except being buggy? I can see changing it to rid it of bugs.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                The good thing they realise is that they have to change to non-destructive workflow. But of course , they are doing it in Autodesk Style
                Available for remote work.
                My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                  booleans nnever worked well with "open geometry"..i mean it works well if you have a solid object...and it doesnt when you have something like a plane...at least for me
                  in your case ...i woudl not even bother booleaning it and went directly to slicing and cutting it up to save me from pulling hair...those who know me already know there is not too many left on my head ))
                  Martin
                  http://www.pixelbox.cz
                    you could try shapemerge instead. you can use planes as the body and use closed splines (a rectangle). It works really well.
                    val valgardson
                    http://www.photorealistic-rendering.com/
                      i do that for roads and stuff. Never thought about it for window openings.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
