Climbing Grass
  • Climbing Grass
    Does anybody know how to avoid this in FPP?
    See the grass on the bottom, right? I have the scale to fit slope areas on, which I need, and it is set to Point, which the edges work. Other than the spike of grass, everything looks how I need it to look.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    havent had this one in a while but a quick fix would be to simply switch into tree mode and delete those patches if everything else is fine.
    www.short-cuts.de
      I painted it out in PS, but I'll keep that in mind. Thanks!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Interesting, I get better luck using Edge for FPP grass. Anyway, I would suspect the distribution surface as the culprit...
          I was able to us UV, opposed to XY, which worked.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
