Forestpack instead of Clone and Align for thousands of objects? HELP
  • Forestpack instead of Clone and Align for thousands of objects? HELP
    Hi
    I have thousands of NON INSTANCED objects. I want to instance a new object to the pivot of each of those objects. ForestPack?
    Max Clone and Align is useless
    Kind Regards,
    Morne
    Looks good. For now I did it old scool, but next time will use this tip from Itoosoft
    Reply from the Itoosoft guys:
    "For these purposes there is the Reference Objects - Distribute Using: Pivot mode under Tree Editor - Creation Tools"
    Kind Regards,
    Morne
      Good to hear and thanks for posting your solution
        If it's only a single object that you want to swap in for the rest, have a look at the baseobject property in maxscript
        If you make a scene with 100 point helpers and one single teapot, try selecting all the points and running:
        for i = 1 to selection.count do
        i.baseobject = $teapot_01
          Thanks John. That sure is handy. I had about 3 times 16 000 "helpers" that needed to be raplaced by 3 single new objects
          Clone and Align didn't want to know anything if I selected more than 2000 objects at a time
          Kind Regards,
          Morne
            http://www.scriptspot.com/3ds-max/scripts/copy-replace
            Alain Blanchette
            www.pixistudio.com
