Tile material question / challenge
  • Tile material question / challenge
    I'm currently working on a large public swimmingpool and the design requires floortiling that goes from dark grey to light grey within a gradient-esque principle. See image (https://s-media-cache-ak0.pinimg.com...6a679ce504.jpg).
    I generally work with floorgenerator and use random mat. id to create a diverse spread of tiles within a colour range (for example dark grey). With a swimmingpool the floor is an important aspect so I prefer having it as geometry and the scale (50+ meters) means I can minimise tiling by combining the geometry with random mat. id and a multimaterial.
    However, besides manually dividing the geometry up to get the gradient effect I'm at a loss how I can otherwise do this. Preferably I would like to add something like a gradient ramp in the random mat id modifyer so that the mat id's can be clustered along a gradient. For example id1-4 at white, id4-8 at grey and id8-12 at black.
    Anybody have a tips or can point me in the right direction? Thanks!
    Dean
    Maybe if you use a gradient ramp with four swatches, set the interpolation to solid so you get four bands of colour. On each colour swatch there's the option to use a texture instead of just the colour of the swatch so you could sub in a random mat in each that uses a slightly darker range as it goes down the gradient? Bercon gradient is handy for this!
      Hi Jo,
      Thanks for the response.
      I'm not sure I understand your solution correctly but I think you are approaching it from a different starting point, which is probably better.
      My starting point it to create 12 materials/multimaterial (variation in colour and reflection) and link them in to a floorgenerator geometry and use the randommat id modifyer to create the randomness. However for the last step I am looking to enbale the random mat's to be organised to create the gradient effect.
      Your version, If I understand correctly, is to create textures with a random colourrange using the gradient ramp and then link that to the geometry. Is that right?
        You should be able to achieve this using Bercon Tiles. It has an option to apply a mosaic style effect driven by a map.
        mekene
          Depending on the need for details, but I would probably use the regular 'tile' map with gradient ramps. Does this knig of thins quite correctly.
          Alain Blanchette
          www.pixistudio.com
            Latest railclone tip may help you : https://www.facebook.com/itoosoft/?fref=nf
            http://www.3dna.be
              Thanks guys, that last one should be perfect!
                http://www.vizpark.com/shop/mosaic/
                there is an example using a gradient map
                show me the money!!
                  Glad that tip was helpful for someone so quickly
                  If you need them there are some sample files on our forum too: http://forum.itoosoft.com/index.php?topic=3880.0
                  Cheers!
                  Paul
                  Paul Roberts
                  Training Manager - iToo Software
                    Thanks Paul!
                    Will check it out.
