MCG:Tubo shape object.
  • MCG:Tubo shape object.
    This MCG shape allows you generate smoothly connected spline between two objects with sagging option. You can animate start/end object. Tubo will dynamically connect two objects while trying to keep the overall length of spline.
    http://bit.ly/MCGTuboVimeo
    As always, it is free to download and use.
    Perfect. Suits my projects right now. Need to animate a ton of small bits of rope. ^^
    Whishlist:
    Being able to use the Gravity ref on the same animated object on several Tubo object within a scene.
      This looks fantastic! Thank you.
      MDI Digital
      moonjam
